Текущее время: Пн ноя 30, 2026 9:59 pm
Начать новую тему Ответить на тему  [ Сообщений: 62 ]  На страницу Пред.  1, 2, 3, 4, 5  След.
 Заголовок сообщения: Re: Замена Масла.
СообщениеДобавлено: Чт фев 19, 2009 3:41 pm
Happy Man
a gde otvet artemu :lol:
koroche filjtr 3-10 Ls,maslo 18 Ls itogo 23-28 Ls.
sam konechno menjaj.po negramotnosti zaehal kak to v YAMAHU....40 Ls snjali :shock:
tozhe bilo lenj,kak govoritsja sapozhnik bez sapog :grin:
Don't worry,be happy...
 Заголовок сообщения: Re: MOTOZONE - TALLINN
СообщениеДобавлено: Чт фев 19, 2009 3:44 pm
wonsigo писал(а):
....отличаются кинематической вязкостью при высоких температурах....
viscosity daetsja pri 50 C a density pri 15 C.eto standart.
SAE 10,SAE 60... :razz:
Не мог бы ты уточнить, какой стандарт???
И причем тут вообще density??
На, читай:
Single-grade
For single-grade oils, the kinematic viscosity is measured at a reference temperature of 100°C (212°F) in units of mm²/s or the equivalent older non-SI units, centistokes (abbreviated cSt). Based on the range of viscosity the oil falls in at that temperature, the oil is graded as an SAE number 0, 5, 10, 20, 30, 40, 50, or 60. The higher the viscosity, the higher the SAE grade number is.
Multi-grade
The SAE designation for multi-grade oils includes two grade numbers; for example, 10W-30 designates a common multi-grade oil. Historically, the first number associated with the W (again 'W' is for Winter, not Weight) is not rated at any single temperature. The "10W" means that this oil can be pumped by your engine as well as a single-grade SAE 10 oil can be pumped. "5W" can be pumped at a lower temperature than "10W" and "0W" can be pumped at a lower temperature than "5W". The second number, 30, means that the viscosity of this multi-grade oil at 100°C (212°F) operating temperature corresponds to the viscosity of a single-grade 30 oil at same temperature.
СообщениеДобавлено: Пт фев 27, 2009 11:26 am
а скажите, масло менять на горячем движке или нет?
мотег у меня стоит на теплом складе (как дома тепло), так вот заводить стоит мотег или можно так выливать и лить новое? мне тут парнишка один сказал что на горячем движке оно быстрее сольется. но торопиться мне не куда, могу открутить и хоть день пускай выливается.
и последнее, фильтр закручивать как можно сильнее от руки или приблудами каки-нибудь еще?
спасибо
СообщениеДобавлено: Пт фев 27, 2009 11:35 am
Jurka666
Перед заменой движок прогревают. На холодном масло выливается не только медленно, но ещё и не всё ... текучесть меньше ...
Фильтр всегда закручиваю руками. Приблуда есть, но ей ты рискуешь так затянуть, что потом вспотеешь откручивать ...
СообщениеДобавлено: Пт фев 27, 2009 11:43 am
На теплом меняют потомучто масло жиже, можно и на холодном менять (криминала нет) - сливаться оставь на день..
Фильтр - маслом смаж резинки уплотнительные и закручивай "от руки".
СообщениеДобавлено: Пт фев 27, 2009 11:45 am
Есть тока одна засада- все дерьмо плавающее в масле оседает на стенках картера и залив свежее масло ты будеш неприятно удивлен его цвету.
СообщениеДобавлено: Пт фев 27, 2009 11:59 am
ну.. эт у которых фильтров нету и вся шняга в картере баламутится и на дно оседает :roll:
"япономать" с фильтрами в масляной системе "засираца" сильно недолжна (хотя на паддоне чето и может оставаца - факт..)
СообщениеДобавлено: Пт фев 27, 2009 12:41 pm
тогда если я заведу мотор, взбаламучу эту гадость, значит она сольется или нет?
СообщениеДобавлено: Пт фев 27, 2009 12:56 pm
Шансов на то, что сольётся на горячем двигателе безусловно больше ... Но если хочешь максимума - после слива сними поддон картера и прочисти.
Да, ещё маленький совет... Когда будешь сливать масло, делай это через мелкий фильтр (я делаю через малярный) Тогда у тебя появится возможность во всех подробностях рассмотреть то говно, которое сольётся... А по ниму можно судить о состоянии движка/коробки/сцепухи ... Так сказать, диагностика по маслу :wink:
СообщениеДобавлено: Пт фев 27, 2009 1:03 pm
а поддон сложно снимается? пластик снимать тоже нужно будет наверное?
СообщениеДобавлено: Пт фев 27, 2009 1:07 pm
Jurka666 писал(а):
а поддон сложно снимается...
..девушка знает толк в извращениях ... от видушего: движек раскидать и зубной щеткой отпид..ть
рекомендуют греть и сливать -хочеш "зебест" делай как рекомендуют. Лень греть - ну никакого крименала не произойдет.. а то ща как "про лампочку" будет..
СообщениеДобавлено: Пт фев 27, 2009 1:20 pm
Это ещё не извращение :razz:
Извращение - это купить магнитный щуп-щётку (на подобие тех, которыми в советское время бутылки мыли) и этой х**йнёй картер censored через сливное отверствие :grin: Это как гланды через задницу удалять :grin: Потом залив масла с очищающими присадками, прогон, слив и залив обычного :grin: Не знаю, кто такой хренью занимается, но инструмент на работе реально есть :shock: :twisted:
СообщениеДобавлено: Пт фев 27, 2009 2:12 pm
не в мото теме будет сказано, но на старой бэмке я занимался :oops: а сподвигло меня на это 2 обстоятельства:
1. на фирме сказали что оплатят мне весь ремонт :ROFL: (ну я сделал всё что мог, новая подвеска и замена всех фильтров/ремней/жидкостей и даже дворники тудаже вписал)
2. я просто люблю свой транспорт :grin:
СообщениеДобавлено: Пт фев 27, 2009 3:11 pm
Happy Man
.....И причем тут вообще density??
;) при том что цена идет за кг или тонну и следовательно плотность необходима для расчета обьёма.
в среднем заказываю в месяц от 1.000 кг до 2.000 кг разных масел.
а с вязкостью уточню: измеряется при 40 и 100 градусах С.
50 градусов ето для топлива :pardon:
СообщениеДобавлено: Пт фев 27, 2009 3:23 pm
Наконец то я понял, чья ЯМАХА жрет масло :))
Игорь, мы тут о мотомаслах в розницу. Их литрами продают:)
